Activesync Calendar Issues
bolagatos
Dec 5, 2007
Hi,
I've looked through the forum and web in general for an answer to my isssue, and have had no success so far, which scares me a little. I've also contacted my corporate IT department, and they have not been of any help thus far.
My setup:
Windows XP SP3 (I think)
Outlook 2003
8GB iPhone, 1stGen, Software v2.0.1
iTunes 7.7.1.11
My issue:
- Contacts and email sync perfectly with my iPhone via Activesync, as well as some calendar appointments. Other calendar appointments, however, are not syncing via Activesync at all.
- What works:
1) appointments set up in Outlook (desktop version) sync to iPhone
2) appointments set up in iPhone sync to desktop
3) invitations accepted by desktop outlook sync to iPhone
4) all appointments sync if I disable activesync and sync the iPhone using the hardwire connection to my laptop
5) appointments set up in webmail sync to iPhone
- What doesn't work:
1) invitations accepted by webmail outlook don't sync to iPhone
2) appointments imported into desktop outlook don't sync to iPhone
Anyone else experience anything like this?
Any help would be GREATLY appreciated.
bolagatos
Dec 5, 2007
Update - I had my corporate email administrator disable and re-enable webmail for my account, and this seemed to have solved the problem. Hope this solution might help others who experience the same problem.
Cheers.
