Add your own sounds to customize
JewelDiamond
Sep 20, 2007
74
I just recently DLed installer, community sources, customize and summerboard. I would like to know how to add my own sounds/songs to customize? Also, how do we add our own background wallpaper to show behind the icons?
Alexander
Jun 28, 2007
1,724
Atlanta
I can answer the wallpaper one!
In summerboard, make sure the "Theme Wallpaper" is OFF, but under Advanced "Wallpaper" is ON. Your icon wallpaper will become the same thing your unlock wallpaper is.
OGrizzle
Jul 17, 2007
I haven't tried it but you should be able to put your sounds in var/root/library/Customize/AudioFiles/
They have to be .aif files. You might have to create a new folder within the AudioFiles folder so they show up properly in customize.
Let us know if it works.
