Adding movie to iTunes
orbi
May 19, 2008
Dubai, UAE
Hi Everyone,
Newbie here... can someone enlight me about adding movie(s) to my iTunes... I tried so many times to add my existing movie in my laptop to my iTunes in order for me to sync it to my iPhone but unfortunately it didn't worked out...
is there any specific file format?
Thanks,
Jerome
Eragon
Jan 8, 2008
3,056
49
Frederick, MD
Hi Everyone,
Thanks,
Jerome
Hi Orbi!
Getting movies on your iPhone is really easy. Just takes a little time to get the file into the right format.
Here is a link to a simple guide:
http://forums.ilounge.com/showthread.php?t=123067
kbtat2
May 8, 2008
I use xvid4psp. It has a setting especially for the iPhone. it's quick and does a nice job.
After you encode the video just drag it into the movie section of iTunes and it will show up for you to sync.
i robot
Jan 29, 2008
747
Hi Everyone,
Thanks,
Jerome
Hi jerome
Download 'handbrake' for mac or pc whatever your format. Use handbrake to decrypt and format your DVD for your iPhone and save it to your desktop. Open iTunes select your movies section and just drag and drop the file in. Your done.
orbi
May 19, 2008
Dubai, UAE
Eiy guys! thanks for all your reply(s)... I already managed to transfer my movie to my iTunes... thanks! i used videora to convert all my avi. format movies to mp4 format...
I really appreciate you all guys!
Thanks!
adambodkins
Jul 15, 2008
112
once you got it converted to mp4 what did you do to get it onto your iPhone cause the movie I am trying to put on my 3g shows up in iTunes but won't sync to my 3g
15,384
1,089
are you sure it's in an ipod/iPhone friendly format?
if not, try what i recommended a few posts up.
if that still doesn't work, my guess is maybe you have your iPhone set to not sync videos or maybe only "checked" videos...
adambodkins
Jul 15, 2008
112
ok i tried that and it says it cannot convert file because it is already in proper format what am I doing wrong here. The file is only like 5 minutes long so I know it isn't too big.
15,384
1,089
are the files .mp4s or .m4vs? if so, then you won't have to convert them. just make sure you have selected to "sync movies" in your iPhone's options tabs.
