Adding music help!
bluefox
Aug 24, 2010
95
Minnesota
Hello,
So I want to add music to my jailbroken iPhone (3GS) but don't want to lose any thing. How would I go about doing this? I noticed that the box for manually adding music is not checked (iTunes).
Thanks!
iphonewarrior
13,847
699
You will need to sync your phone through iTunes. Check the box which allows you to sync all music. :)
bluefox
Aug 24, 2010
95
Minnesota
So if I hooked up my phone to iTunes and changed the settings, when it says it will erase what's on there it's just the music?
