Adding Music w/o erasing current tunes?
rmu2unc
Jul 23, 2008
I loaded a bunch of songs from my computer and tried to add songs from my roommates computer which erased all the current music. Is there anyway to avoid that?
Jul 23, 2008
Yeah, Just Select Manually Manage Files in your Settings
Jun 27, 2007
21
I believe if you just check "Manually Manage" it will give you the "This iPhone was synced with another computer, you must erase..." BS message.
The only way I found to be able to add songs from two computers to the same iPhone is to hack the library ID number stored in
C:\Documents and Settings\<userid>\My Documents\My Music\iTunes\iTunes Library.itl
and
C:\Documents and Settings\<userid>\My Documents\My Music\iTunes\iTunes Music Library.xml
You need to set the library ID to the same for both computers.
The XML file has the hex library ID, and you will need a hex editor to edit the idl file which is binary. The library ID is in hex near the beginning of the idl file.
