Adjustable 3G holder Pro clip
DavidT
Aug 15, 2008
170
Baltimore MD
I just got the ProClip (www.Proclipusa.com) 3g holder for my car. this holder will fit the 3G the original and the touch. it is adjustable from 2.3" (60mm) to 3.2" (82mm) in width. it will also hold the 3g with a skin on it. simple put it works great. The model number is 875214
