Advanced Preference Settings?
H
Hayesimus
Guest
so i downloaded this via installer and then i went to my sounds settings and now there is something called clicker. what is that? you can only enable it when the volume is all the way up.
mflantin
Nov 29, 2007
100
I didn't see any other changes other than this either... looks like a perfectly worthless download.
H
Hayesimus
Guest
they have already updated it twice LOL.
15,385
1,089
if you click on "more info" there's a list of the other options. some of them are interesting... i think i'll keep it.
here are the ones i like:
-Auto-dim. My phone is set to not auto-lock, so this is helpful to conserve battery power if i leave it on for whatever reason without using it.
-Custom strings in Carrier and Time slots in status bar.
H
Hayesimus
Guest
I'm not seeing anything when I click more info. What else is there
15,385
1,089
-Enable/Disable On-the-Go
-Show/Hide YouTube
-Show internal Apps (Shows/Hides apps put in the directory /Apple internal/Applications)
-Auto-Dim
-Fake Signal Bars
-all Summerboard Prefs
-a place to type in the name of a custom summerboard theme
and More!
i don't really understand why you would need a lot of those... other apps do most of them already.
OJsakila
Jul 15, 2007
3,021
Jupiter's sulphur mines
For a bunch of "worthless" apps, it's still pretty cool. First app that was applied to the settings.....I kind of dig it......
H
Hayesimus
Guest
well, i'm not sure its doing anything worthwhile. i can't even tell if the settings i've changed remained like i wanted. i dunno
H
Hayesimus
Guest
ok ever since I downloaded this, I haven't noticed any changes in the settings of my phone. Except now after my phone is on for a while the battery icon disappears and then just displays the percentage number. Like 96 or 75 and all of my alarms have been erased. So I'm lucky I woke up for work on time. Yeah. Not impressed so far
15,385
1,089
if you tap the battery it switches back and forth. most of the settings are in the settings under "interface". you may have a weird default giving you problems.
OJsakila
Jul 15, 2007
3,021
This app has screwed my stability up.....My "settings" have disappeared altogether and am now trying to find the 1.1.2 firmware so that I can rejailbreak........
H
Hayesimus
Guest
hey! Neat I tapped it haha. But why did it delete my alarms? That coulda been very bad!
15,385
1,089
yeah, i don't know why that happened. I only use it for the auto-dim. I'll keep a close eye on it, and uninstall if i notice anything weird.
aredling
Oct 26, 2007
This program has rendered my iPhone useless. The touch screen and the buttons on the iPhone no longer work.
Any suggestions?
iTunes recognizes it.
mflantin
Nov 29, 2007
100
Any suggestions?
have you tried holding the power button down for 10 seconds?
15,385
1,089
yeah, this app is terrible. i had to restore because of it.
stay away.
H
Hayesimus
Guest
yep, it just deleted my alarms again. i'm deleting it
