Afraid to update my iPhone
moka987
Oct 24, 2007
I bought my iPhone the day it came out so i have the oldest firmware on there because i haven't updated it at all since then. I used jailbreak once or twice to put some ringtones on there to use and now im not sure if this falls into the category in which my iPhone becomes a brick if i try to update it. Any advice anyone can hook me up with?
kingofthechi
Oct 15, 2007
30
if u are with AT&T then nothing will happen just restore the phone and then update it. But if it's unlocked it will brick and you'll need to use one of these methods to use it again
mittenman
Jul 25, 2007
813
Nowhere, Mitten
Just make sure you do a restore to an older FW version before updating. Right click on restore and it should give you an option aon diff firmwares (unless you've updated iTunes to the newest version).
papabro
Jul 23, 2007
101
MA
How can he update to an earlier firmware when he bought the phone on day one and has never updated his firmware?
papabro
Jul 23, 2007
101
MA
I would update your iTunes to the latest version and then update to 1.1.1 firmware on your phone. Because you have broken out of jail it is going to force you to restore. You may consider syncing if you have added contacts and such to your phone and they are not on your pc. You could also restore before updating your firmware as a separate task if you wanted to take baby steps. Once you are on 1.1.1 you can then jailbreak again by using the following instructions:
Go here for an even easier guide:
http://forums.everythingicafe.com/threads/guide-easy-jailbreak-1-1-1-without-restoring-to-1-0-2-windows.12715/#post123403
