After a search, 1.1.1 Summerboard, Jailbreak Instructions
velvetropeparty
Jul 4, 2007
56
I see the WINDOZE instructions for a jailbreak and install of summerboard to 1.1.1, but I am not finding the detailed step by step instructions for Mac users.
Anyone?
velvetropeparty
Jul 4, 2007
56
That requires you to downgrade to 1.0.2 first, I understood you could now do it without a downgrade.
Tinman
4,334
183
Aridzona
You should be able to use that guide with a 1.1.1 iPhone if you start on step 7. All you need to do first is run the tiff expoit via Safari (by visiting Link removed, website no longer available -- don't go here unless you want to jailbreak!).
Also, that guide doesn't say to close iTunes at step 7. Unless there is some reason, such as iPHUC needing it, I would close iTunes. The symlink that is used as part of the jailbreaking process confuses iTunes and if it's open it can add additional Media folders to the iPhone.
Speaking of the symlink, this guide doesn't get into it but you will need to remove it for normal syncing. I assume if you keep following the links they will eventually get to it (maybe after BSD). When you get to that part it will look like this:
rm /var/root/Media
mv /var/root/Media.old /var/root/Media
The process to do this after using the tiff exploit is a little different:
rm /var/root/Media
mv /var/root/Mediaold /var/root/Media
As you can see the only difference is the "." in Media.old.
Of course you could skip the guide and use this instead:
http://www.ijailbreak.com/
Mike
indydenny
Jul 4, 2007
9
I have seen no evidence that the last option:
"Of course you could skip the guide and use this instead:
http://www.ijailbreak.com/"
. . . would work on an iPhone.
Do you know of anyone using this with success?
Aug 9, 2007
178
a lot of us have used it on our iPhones.
thanks to tinman's guidance.
Tinman
4,334
183
Aridzona
Worst-case, you can restore and use the longer guide. None of this changes the baseband, so your chances of bricking are slim to none.
Mike
mediarite
Jun 20, 2007
97
ColoRADo
