after I jailbreaked
wb1960
Jan 2, 2012
Whenever I go to cydia and try to purchase something(or anything for that matter) it says "can't locate package" why is is this happening
wb1960
Jan 2, 2012
a reboot did not fix it I tried jail breaking again but couldn't because it said device is already jailbreaked. Anyone help here?
fijiman
Feb 13, 2011
832
64
UK
In Cydia go to Manage>Sources> check the content of the BigBoss repo....if nothing is present....just ADD any repo...this will refresh all the repos.....Good luck;)
In Cydia home page use the tab "More Package Sources" to add a repo
MoneyMaker79
Dec 15, 2008
5,386
340
30
Pensacola, FL
I had the same problem. I had to restore, then I rejailbroke (wd?), and was able to get Cydia to behave. You might try it.
I agree with Michael here. Sometimes a jailbreak may not go smoothly, causing Cydia to not work properly. If it still does not work properly, make sure you have repository packages available.
