after jailbreak on 1.1.1 3rd party apps open then close
spampy22
Jun 8, 2007
165
46
Columbus, Ohio
ok, I have 3rd party apps like fivedice, ilight, and others on my phone and everytime i open them they try and open then go right back to home screen. I have restored and tried again with no luck. I even restored and rejailbreaked the phone.
Help!
Tinman
4,334
183
Aridzona
Help!
It sounds like a permissions issue. How are you installing these apps? If manually you need to set permissions or else the apps cannot execute. When that happens the behavior is exactly like you described above.
Mike
stevenshizzle
Jul 9, 2007
34
I find that sometimes, just like a real computer, a good hard restart does the job :)
spampy22
Jun 8, 2007
165
46
Columbus, Ohio
I'm using the installer app to install 3rd party software.
I have also tried hard restarting as well.
Any insight would be great.
lido
Oct 23, 2007
27
I'm having the same problem. How do I set the permssions?
tia
spampy22
Jun 8, 2007
165
46
Columbus, Ohio
I have no I dea why this worked, but what I just did was go into Summerboard change the hide the last row to NO then install customize from Installer. Once I got Customize on the springboard I tried to open it up, but it just opened then closed like my previous post, I tried again and it open for some reason and now my other apps are opening as well.
Strange!
lido
Oct 23, 2007
27
Well, I figured I'd try that as well, but I cant find the option in summerboard to "hide last row". Am I missing something?
lido
Oct 23, 2007
27
didn't work. sigh. I was so excited when I donwloaded all of these apps from the installer, and only some of them will stay open! Help!
spampy22
Jun 8, 2007
165
46
Columbus, Ohio
I don't know what else to tell you. I faught with it for over 2 days and now it works. Can't explain!
junkie
Jul 17, 2007
23
I am having the same issues. I am assuming it has to do with permissions but am not intelligent enough to figure it all out :)
Any help would be great !
lido
Oct 23, 2007
27
just an update:
last night I downloaded bsd subsystem (unrelated to this issue) and after that was downloaded, all of my apps worked!
so that's the happy (although mysterious) ending to my tale!
