after upgrading to 1.1.3 via iPodtouchmaster way i cant install apps
apaschea
Feb 17, 2008
ok so i followed the guide on youtube to do the upgrade and jailbreak from 1.1.2 to 1.1.3. Everything works perfectly exept for the fact that when i try installing an app it says installing then when its done it jstu goes to the home screen and the app is not there !
is there something else i have to install first?
I'd just like to add that I was able to install a theme. I didn't see any change on my iPod(maybe I have to set the theme?) but I did see that I could uninstall it in installer
singlefilerock
Dec 27, 2007
82
i had a same problem
when i set a theme and went to home..it didn't show.
after rebooting it a couple times just from doing other things it then appeared.
[background and icons]
maybe that would help?
