Agent 18 case dock question
ritzthekracker
Sep 9, 2007
53
hey guys, I just bought the agent 18 eco shield from the Apple store and just realized that the phone doesn't sit in the Apple dock with the case on. The case also came with a snap on dock of sorts but i don't know what to do with it. Has anyone else had this problem, and if so whats the best solution as I want to keep using my dock to charge my iPhone?
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Do a search and you will find the review of the case and the solution to the dock.:)
420greg
Jun 26, 2007
845
Orlando, Florida
The adapter that comes with the Agent18 case os for the universal iPhone Dock. The one that also holds the bluetooth headset. If you get this dock the iPhone will sit in it with out removing the case.
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
The universal dock doesn't hold the headset - that a different dock. The universal dock only holds the phone/ipod. That's what the adapter is for.
If you don't want to buy a universal dock, simply remove the case, or you can plug directly into the phone, and just bypass the dock.
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
You might have to go an Apple store or go their online store.
Actually, I think best buy or circuit city may have them too...
