Air Sharing MacBook
drub
Sep 20, 2008
I can't get the Air Sharing app to work with my iPhone 3g and my macbook pro. When I try to connect using my computer, it says "You cannot connect to the server because it cannot be found on the network."
My iPhone and my macbook are on the same router both accessing the internet/emails just fine.
Any help is appreciated!
dru
showguy
Dec 2, 2007
769
Long Island, NY
Check the settings and the IP address carefuly. It took me a couple of shots before mine took it.
drub
Sep 20, 2008
I got it to work when I enabled bonjour on safari. Then I saw that the address is different from what air sharing was telling me to put- I need to use http://iphone-2 instead of just iPhone.local. Thanks for the help
