Air Video Server Pin?
Nov 9, 2012
137
What is a air video Server Pin? it's not the iP address i know this.
28,365
5,507
Do you have UPnP enabled on your router? It's easiest if you do, otherwise you have to set up port forwarding.
Nov 9, 2012
137
where do i enable UPnP on router i have a netgear nighthawk?
There is no need to answer the question question,i am not going to try using AirVideo now using AirMore it's simple to get going and it works well also it is now FREE.
