AirFloat
efuseakay
Nov 11, 2008
864
99
Just saw this on Cydia... Apple removed it from the App Store awhile ago, IIRC. It turns your iPhone/iPad into an AirPlay device. It's working good so far. Find it in the BigBoss repository. :D
Once installed, run the app. and close it. Open up iTunes on your computer, and select your iPhone/Pad like you would any other AirPlay device. Then go into your device/Music App, and click on More at the bottom, then Shared. Select the library on the computer and you're good to go.
chavezr6
Sep 9, 2007
Can't find this in Cydia.
Edit: I found it. Was searching AirPlay and not AirFloat. :cautious:
