Airplane mode or WiFi Off
Nance Hall
Aug 9, 2011
20
Crafton, PA
I'm not sure if I'm on the right topic or thread.
But anyway, I have question that really need an answer. I'm a bit confused about it so I would like to ask for your help. Seriously, what is the difference between airplane mode or wifi off? At first I thought it was just the same. :unsure:
Iloveiphones
Aug 5, 2010
6,237
234
chatsocially.com
Wifi off is just wifi off. Airplane mode won't let you make calls, make data transfers or text. An iPod really.
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
Can I use airplane mode setting even if I'm not flying or not in the plane?
Yes. If u want to just use the functions on your phone an not be able to send or receive anything u should and can use airplane mode. Don't worry even with steve jobs having more free time he won't come to your house and spank you for using airplane mode.
It is just names airplane mode because as phone evolved into more than phones people wanted to play games or listen to music or whatever while on a plane. Airplane mode allows this. Old phones had on or off that was the only way to prevent the sending or receiving of data
