Airport Extreme help please
Jul 6, 2013
i have bought and setup an airport extreme, all seems to be going smoothly until l tried to set up a guest network, well i thought the initial setup was easy enough asking me to set a password for the guest network which i done without any bother but when i try to connect to the guest network on my iPhone i pad etc. it asks for password and accepts it but does not connect i just get that pin wheel spinning and no check mark
also when i open airport utility on my MBA I get the two green lights one on the internet picture and also on the AE, in the top left where it says other WiFi devices when i click this everything is greyed out, shouldn't it find my i pad and iPhone?
have i got a duff unit?
RBNetEngr
Jun 17, 2013
170
27
What other options did you enable on the AirPort Extreme? Did you set up a private network as well as a guest network? If so, does the private network connect properly?
-rb
