AirPrint
Rcspott
Mar 3, 2011
Do both the computer and the printer have to be running to print with AirPrint or do some printers just need to be on.
The computer does not need to be on if you have an AirPrint-enabled printer. If you don't have one of the supported printers, and you're using an app such as AirPrint Activator to enable it, the computer will need to be on.
Supported printers:
http://support.apple.com/kb/ht4356
