Album Art Dilemma
topcat84
Jun 28, 2007
289
26
I've noticed that when iTunes doesn't find album art and I have to manually copy and paste it into iTunes from my desktop, the album art shows up in the very first song, but none of the others. What am I doing wrong ? Like I said, it shows up perfectly when you look at the cover flow or when viewing albums, but in the playlist it only shows the album art in the very first cut.
I also would like someone to tell me how I can delete an individual song off my iPhone. I've looked in the manual and don't see instructions on how to do that.
Thanks in advance. Cheers !
Wiggo
Jul 7, 2007
103
Memphis
You have to paste it into all the songs on the album. Select them all, select "Get Info" and paste into the artwork box. Voila.
topcat84
Jun 28, 2007
289
26
Thanks SOO much Wiggo ! Now......how do I delete an individual song ?
Iceblinkluck
Mar 30, 2007
129
Long Island NY
You need to delete it or uncheck it in iTunes. If you are just syncing a particular playlist, just remove it from that playlist. If you are syncing an entire library, you can choose in preferences to only sync checked songs. You can uncheck the box next to the songs you don't want to sync and then they will no longer be synced. If they are presently on your iPhone they will be removed.
latinnftl
Mar 19, 2007
61
Part of the reason it does that, I've noticed, is that iTunes doesn't always recognize that a group of songs are on a particular album. When you do the "Get Info" you have to be sure that the group of sounds say "Yes" to compilation, otherwise it's not recognizing it as one album.
