Album art iTunes.
FatCobra43
May 1, 2011
Does anyone know how to set up album art in iTunes? I'm copying and pasting album art one track at a time but I can't figure out how to do the whole album at once. It would really save a lot of time. Thanks in advance.
iphonewarrior
13,847
699
Select/highlight all of the tracks in the album, right-click and tap "Get Info". You'll see a pop-up window with album artwork in the bottom right-hand corner, drag the album artwork into that space and it'll set that artwork for all songs within the album.
flightmedic
Jun 21, 2009
397
23
Wichita Falls, Texas
On iTunes 10.4, there's a bug where you cannot post into multiple files at once. It's been reported according to other forums, and they will fix it in next release, or so they say. I'm waiting for it myself.
Jim
Sandeep Senggutuvan
Sep 5, 2011
23
Jalandhar, India
If you set up an iTunes Store account, you can automatically get your album artwork by logging in with your Apple ID, selecting all of the tracks in your iTunes library (CTRL+A), and right-click > selecting "Get Album Artwork" chances are it will fill out at least some of your albums with their artwork.
I currently don't have purchased songs off the iTunes Store and that is why iTunes will not find artwork for many of my albums (it does the job okay to an extend though...).
Edit: there seems to be something cooking here. Seems like a new tool for id-ing and adding missing artwork. Let's see if it is going to be useful...
flightmedic
Jun 21, 2009
397
23
There's a good portion of my playlists that iTiunes can't find or puts erroneous art in for the album artwork. Most of the time I enter it myself.
Click on the first song that control click the last song on the album, right click to info then add the album there also. Another option is to control click the whole album and then drag the artwork to the "now playing" window in the lower left window. That will populate the whole album, so long as all songs are highlighted. Hope this helps.
Jim
