Alex voice on iPhone not working
Jun 15, 2009
Got a iPhone 2G jailbroke
installed alex voice was working fine
intalled other apps and alex voice now only works when phone is plugged into power.
it used to say things like iPhone locked and so on
I removed all apps I installed and reinstalled alex voice and winterboard
still don't work.
anybody have any clues on whats wrong?
Mar 2, 2009
3,322
43
California
Were you using any other themes that included sounds that may have overridden the sound pack of Alex voice? You can generally only use one source for sounds, if you have more than one enabled they just won't work.
Did you try moving the Alex sound pack to the top of your Winterboard theme list? That usually helps.
