All Cydia Sources GONE!
fearofnormalcy
Jul 8, 2010
1,742
118
New Port Richey, FL
www.facebook.com
Okay, a buddy sent me a text saying all his sources had vanished from Cydia...upon opening mine, I too got this message "Error: Database Problem parsing dependency suggests", and to my dismay, ALL my sources are gone. Everything else seems to work...the Cydia home page comes up, however it no longer shows my saved SHSH blobs.
Is this something that will be remedied on Saurik's end, or do I have to restore AGAIN?
5,580
No worries. Your SHSHs are still stored on his server. The indication of the saved blobs is not always accurate.
As far as all sources, you'll probably just need to wait until it's available again. I added them all once and I wished I hadn't. It increased the Cydia load time quite a bit. That was on the 3G, though.
Peacekepr
Jul 30, 2010
65
Thank God - thought I was the only one and was worried as the SHSHs were gone!
Was worried that I would need to do a restore and was worried I would lose my jailbreak!
iphonewarrior
13,847
702
ZodTTD/MacCiti uploaded a corrupt Package.
According to this...
I'm getting sick of these guys doing this, they've done this quite a few times now.
It says it's been resolved, but I'm still having the same problem. I have also rebooted again. I would rather not have to restore. But if that's the case I'll wait until the the JB for 4.2 comes out and then start over.
offroadhunter
Apr 1, 2009
682
22
New York
It'll be back up, just temporary.. I had a few updates earlier today and there's nothing I need right this second that can't wait.
iphonewarrior
13,847
702
I think a lot of people are still having the same problem. I get an error when refreshing, it's a total pain when this happens. Hopefully it'll correct itself and you/I wont have to restore.
I'll post anything info I find in this thread.
5,580
Agreed. Those that are experiencing problems just need to give it a little time. I really doubt this is going to require a restore...
iphonewarrior
13,847
702
I have every faith that it'll sort it's self out. Cydia's having a few hours off.
dalvar3
Jan 26, 2011
Update from my end right now, cydia not working either, no shsh, no sources, no packages. Hoping this gets sorted soon. THis kind of issues freak me out for a possible painful restore.
{StatuSChecKa}
Jul 7, 2010
812
29
NorCal
I to am having this issue as well. Nothing under the Changes tab.
All well, will be fixed soon I suppose. Glad i'm not the only one.
crystus
Jul 5, 2009
258
Deltona, FL
You could always manually update or reinstall cydia through ssh. I had the same issue happen and manually updated to the a newer cydia version and once that was complete all my sources were there. No restore needed.
iphonewarrior
13,847
702
You can do it all from the phone. If you want to manually attempt this, use Mobile Terminal.
Tarek
Jan 26, 2011
Same problem for me.
I have the same problem with the same message. "Suggests"
This is different than the standard message which is "conflicts".
I will now wait and see if it fixes itself as the thread suggests. :p
dalvar3
Jan 26, 2011
I tried to make an update (apt-get udate) to Cydia through Terminal and even reinstall (apt-get remove cydia / apt-get install cydia) but it is not working. We will have to wait.
iphonewarrior
13,847
702
Cydia's fixed! Yay!
Launch the app, let it download new packages. If you get an error, hit changes, then tap refresh. Job done!
Tarek
Jan 26, 2011
Well it is now up for me. Everything is back to normal.
Patience everyone....
