All-in-1 car unit minus FM transmission
psylichon
Oct 31, 2007
16,591
751
41
Philly
Hey guys and gals...
I'm finally going to bite the bullet and get a mounting system for my iPhone in the car. I would like one that has flexible positioning, can handle a phone in a case (seidio super slim rubberized hard case), has a dock connection for charging via 12v outlet, as well as a music connection (ideally also through the dock) that can run to the 1/8" aux in jack in my Element.
I've perused the store here but haven't found anything that fits that description. Lots with FM transmitters, which I don't need or want. Am I bad at looking for things, or is this particular niche not yet filled?
Thanks for any insight...
Dec 10, 2007
710
blacked out
Damn you're right it is frigin hard to find anything that matches you criteria. BUT I think I may have found it.
Kensington Car Charger Deluxe for iPhone and iPod
Features
  • Dock charges most iPhone and iPod models- even with cases
  • Allows hands-free speakerphone conversations
  • Arms adjust around iPhone or iPod for secure fit
  • Cradle rotates for vertical or horizontal viewing
  • Flexible gooseneck adjusts for optimal positioning
  • LED light indicates power status
  • Auxiliary-in cable included to play iTunes directly through car stereo
http://us.kensington.com/html/14486.html
mittenman
Jul 25, 2007
813
Nowhere, Mitten
http://catalog.belkin.com/IWCatProductPage.process?Product_Id=193794
I have used one of these, but do not own one. It has a jack on the cig. lighter part for a 3.5mm cable and a gain adjust dial. You could use this in conjunction with any mount you want so you're not confined to having to mount it from the cig. lighter? It's not an all-in-one solution, but may give you more options.
They sell these at Target also!
psylichon
Oct 31, 2007
16,591
751
41
Philly
I knew I could count on the EIC to come through. You guys rock.
That first one is perfect, feature-wise, but I'm unsure whether that mount will work on the Element dash.
The second one might be better... pair it with a mount that works.
Regardless, I will post pics of whatever I get. Thanks again, guys...
mittenman
Jul 25, 2007
813
Nowhere, Mitten
Hey man, always here to help............ and make wisecracks when needed.
I think some rubber-bands, duct-tape, and a couple coat hangers should make a nifty mount for you box (aka, Element).
JimD
Dec 15, 2007
412
New Market, MD. USA
