Alright...well what can you do with 1.1.1
dietPEPSI
Jun 29, 2007
80
I was just forced to update because i needed to reformat my phone...so now i lost everything.....
Can i at least put my old icons back? or my ringtones back?
Is the only thing that you cant do 3rd Party Apps?
tdefriez
Jul 2, 2007
139
You can do some 3rd party apps
You can but you need to be able to use scp and ssh. Also not all applications work
dietPEPSI
Jun 29, 2007
80
iBrickr wont work will it...
Thats the only way I know how to do it.......
So if that don't work I guess im done modding...
Rockky
Aug 8, 2007
333
Theres an 'easy' 4 step method here if you search a few pages that'll have your installer app on the 1.1.1 in no time.
I then went to ibricker and downloaded a good number of things.
good luck!
