iMac Alt key
Ozzie5374
Nov 7, 2010
422
43
Country South Australia
Hi folks. I'm reading about downgrading to 4.3.3 and the article refers to holding down "alt" key and restore in iTunes. Using wireless keyboard and iMac, is "alt" actually the "option" key? Thanks
iphonewarrior
13,847
699
Nope, you will need to press alt and click Restore at the same time :)
You will need to hold modify your hosts file as well, if you haven't already done so.
Ozzie5374
Nov 7, 2010
422
43
Thanks for that. Tried the alt/restore with downloaded 4.3.3 ...... Still trying. Keeps being rejected. Realised problem - run TSS server in tu. Thanks for advice.
