Alternate Installer/AppTap Source
x999x
Aug 6, 2007
1,656
Hey Y'all, I just stumbled upon a new source for Installer/AppTap. Its basically a ton of themes for pretty much everything, even the keyboard, as well as more ringtones and a few odds-and-ends apps.
To add these new sources to your Installer/Apptap, just download attached PackageSources.plist to var/root/Library/Installer/
If you want to delete this new Source, just go to Sources and delete the entry "HighTymes.org"
NOTE - iUnlock is available as an UNSUPPORTED HACK in the application list, I do not recommend you fiddle with this out of curiosty. lol
I've taken some pics of whats available to save yourself the install time.
iShare Install Code & Instructions
If you want to install this through iShare, you'll first need to use MobileFinder and browse to:
and delete PackageSources.plist
Next, launch iShare and download the new PackageSources.plist to the directory above using the code below:
PackageSources.plist: secf0y
Original PackageSources.plist: r6etau
(delete the alternate PackaeSources.plist with mobilefinder first)
*Note - you may need to press the folder labled ".." to browse up one folder and so on until you reach the main directory where the "var" folder is found. Once there, tap it and keep browsing "root" > "Library" > "Installer"
jjvaldez
Jul 3, 2007
2,615
32
Salinas, Ca
i have installed this but i haven't installed any of thte cool stuff that is on there, there are warnings that say that doing this might be unsafe.. i don't know if i can trust this...
i rather not ....
i deleted the origionala installer file can somone PLEASE post it via ishare PLEASE.. thanks
iphonecrazyy
Aug 15, 2007
111
Awesome, had no clue about this. I Plan on re-hacking my iPhone pending the feedback from the new iPhone update, and I will definitely give this a try.
thanks
x999x
Aug 6, 2007
1,656
i rather not ....
Bilal
Sep 25, 2007
207
Using Ishare i just find
library/installer/temp/ and there is nothing in temp
Anyone wanna help me out
jjvaldez
Jul 3, 2007
2,615
32
Salinas, Ca
i share does not let you see all the files that are there... don't dump it in the temp folder just dump it in the same area that folder is in.. just rememebr to move the origional file first.... you cannnot have both files with the same name in the same place.....
good luck
Bilal
Sep 25, 2007
207
good luck
How do i dl from ishare.
I go to ishare and then add the code to the existing download url.
It takes me to a folder containing library folder and media folder.
What do i do from there?
x999x
Aug 6, 2007
1,656
x999x... what do you think about the sutuff that is on threre? have you ised any of it even after the warnning?
thanks
I have 2 rules of thumb with my iPhone and mods/hacks/apps and its this:
1 - I won't install software that physically affects my default files, like images and plists. I don't have a full backup of my iPhone and you'd be amazed at the differences between one site's "default icons" compared to another's.
2 - I won't use programs that take my iPhone farther than just being able to run native 3rd party apps. Those types of hacks usually involve command lines, and for me thats always a recipe for disaster.
So, of what I have tried and seen in that new Source theres only one real thing I had a problem with, and that was iUnlock. With the iPhone update around the corner I don't even want to see iUnlock's info page in installer, so I mentioned it in my original post as a warning to others. I mean iBrickr has AnySIM in it's repository so its not like this new Source is intentionally devious.
Lastly, this alternate Source was brought to my attention on another forum, it's maintaner actually packaged my TapTapRevolution graphic mod and added it to his Installer source. Notice it in the first screenshot? COLORS: TTR Theme ;) Now installing the mod is as simple as one click!
jjvaldez
Jul 3, 2007
2,615
32
Salinas, Ca
you are close .. dump it in the var/root/Library/Installer/
hope that this helps
snowcrash
Jul 7, 2007
163
Its kinda weak. I installed it and tried some of the themes and stuff like that but over all they wernt that good overall. It was cool to have some more stuff to choose from, but overall I didn't see anything that impressive to go through the effort to install the new file.
bgattis
21
If I wanted to add these manually since I am at work how would I go about doing this. There are two different links for each. I have tried adding them in by the url and it doesn't look right.
xSoNiCcRaCkErSx
Jun 30, 2007
226
Is it just me or have previous applications on the old installer source gone missing? And a lot of the themes don't work on 1.0.2 for me at least. Are a majority 1.1.1 summer board themes? I think I'm going to switch back to the old. Good source though, thanks x999x
Tinman
4,334
183
Aridzona
I think one of the sources has a different URL now, so if you use the plist from the first post it might have the older links.
Try the one attached to this message--it works fine.
MIke
