Alternatives to tapatalk
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Thanks again guys, I got it all figure it out for now, it's not that bad, I didn't know I was this lazy. its only a couple extra steps, I'll use safari till the app starts working again. I'll try not to post on Friday since it's supposed to go to about 115 with the heat index, I'll be a cranky Mofo.
Appreciate the help :)
Bennyboy
Jul 21, 2010
14,017
1,731
PA
After 3 days tapatalk starting working again, go figure, you can lock this thread down if you wish. at least now I know if it happens again how to use safari to post pictures. thanks again guys!
Photobucket has direct links with the image tags already added in so that will save you a few seconds. On your computer, just move your cursor over the thumbnail image and then select the image code. On your phone, click the i in the lower right corner and copy the bottom code (IMG).
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Yeah I found it right away, I already tested it out on couple forums including this one and it worked. I kept hitting the share button but all it gave me was email Facebook and twitter.
Bennyboy
Jul 21, 2010
14,017
1,731
PA
It's def. Good to know, I had photobucket but never used it, even with the app it's faster using photobucket than directly uploading from the app.
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Everytime I update either the EIC app or tapatalk I always have problems, the best way is to delete the app and re-installing the latest version.
iP5
Sep 7, 2010
2,964
136
Toronto
Sometimes I get similar problems with the Android version but fortunately it's something I can fix.
Sent from my Desire HD using Tapatalk
Bennyboy
Jul 21, 2010
14,017
1,731
PA
The last update has been nothing but crashes. When it works the app is worth the money plus 10, it's super smooth and fast. I have a nervous breakdown when it doesn't work thou LOL
Fuggedaboudit!
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Here we go again. now I need to wait for the miracle. out of 147 apps on my phone this is the only one that drives me crazy lol
