Altitude App.
Jul 3, 2014
133
Sweeden
Peace iCafe'ers!
Is there any altitude App that only show how high you go and not subtract when you go down?
This is how I mean:
If you should climb a mountain that is 200 meters. Then I want the Altitude App to "save the highest spot." So when I climb down and reach same place that I started from, I want it would say 200 meters, and when I climb back up to the top again, then it should say 400 meters.
Is there any Altitude App that works like this?
Or else an App that you can pause when you are on top of the mountain and press continue when you stand at bottom.
Then you could climb this mountain 45 times and that would be a high as Mount Everest!
//Thanks a lot for info!
RoofMonkey
Jun 21, 2010
8,867
2,047
Altitude meters use the GPS in the device, so I'm not Tulare there would be any that would continue to add them together, as that would not be your altitude.
If you climb 200 meters 5 times, you are still only at 200 meters
Jul 3, 2014
133
Sweeden
...Go to the App Store > Tap "search" at the bottom > Tap search bar at the top > type in your search subject> Tap go...
Lol, I'm sorry.
I must have typed wrong when I used my translator App...
I see when I type the correct thing, it's just a "step-counter."
Can those even count height?
