Annoyed by Summerboard. Why don't I have it?
brooke03
Aug 31, 2008
104
33
Memphis, Tennessee
Okay so apparently I don't have Summerboard installed. I have searched all through Cydia, etc and can't find it. I have Customize and Winterboard installed right now... Customize used to load themes in the browser but nothing even comes up there anymore (reinstalled, etc.. nothing). But I'm not worried about Customize at the moment. I just want to know where I'm supposed to download Summerboard? I went into SSH to find the Summerboard folder and it doesn't exist. Where the heck do I get this program from?
LionOfTheSouthUK
Jul 23, 2008
82
If you download the Neurox Leopard theme via Cydia it will create the summerboard theme folder. You still use Winterboard to access the Summ
erboard themes.
I wonder if you can just create the folder yourself :eek:
brooke03
Aug 31, 2008
104
33
Memphis, Tennessee
erboard themes.
I'll try... where exactly should it be?
LionOfTheSouthUK
Jul 23, 2008
82
private\var\mobile\Library\SummerBoard\Themes\
edit : Please note the capital letters, no idea if it matters, but that is how it is on my phone.
brooke03
Aug 31, 2008
104
33
Memphis, Tennessee
Customize needs to be updated for FW 2.1
I haven't changed anything on the phone since the last time I used Customize just fine. I bought it with 2.0.2 on it and haven't changed that. I didn't install the update that came out last week.
SummerBoard itself is no more, or at least for the 2.0 + firmware versions; Winterboard is much more powerful and can handle SummerBoard themes, so it's much taken it's place.
brooke03
Aug 31, 2008
104
33
Memphis, Tennessee
Ok well I downloaded a theme and I have Winterboard. Where do I place the theme folder in SSH?
LionOfTheSouthUK
Jul 23, 2008
82
If its a Summerboard theme then
private\var\mobile\Library\SummerBoard\Themes\ your theme folder here
Both WinterBoard and SummerBoard themes can be placed in /Library/Themes/ and will appear in WinterBoard.
LionOfTheSouthUK
Jul 23, 2008
82
I know you don't, thats why I suggested downloading the neurox leopard themes, because its the only theme that I am sure is a summerboard theme(im not a big themes guy).When you download it via Cydia SSH to private\var\mobile\Library and you will see a new folder called SummerBoard .In that folder will be a folder called Themes and inside that will be Neurox Leopard.
In my first reply when I said about creating the folder yourself, and you asked where to put it , I meant create a folder called SummerBoard ,with a folder inside called Themes and place it in private\var\mobile\Library.
