another bug i noticed...
Zman-iPhone
Jul 26, 2007
ok, so here is what you do to see.
put your autobrightness OFF
turn off your phone and then turn it back on and you will see that auto brightness is reactivated, but it says that its off.
oh and one more thing, what is better, Auto-Brightness OFF, or Auto-Brightness ON?
iPhobos
Jul 25, 2007
201
Auto on if course! Save battery life and better viewing in the sun. I haven't noticed that bug but it probably does have to do with Apple always wanting their battieries to last longer.
MoJoe
Jun 28, 2007
94
www.joebeleznay.com
I also had been noticing this slight bug. I thought I was going crazy because I had set the auto-brightness to "off" and when I would bring the iPhone out of sleep a few times, the setting was def "on" even while showing "off".
I usually leave it off and find my battery last longer for some reason.
Joe
Hondamaker
May 14, 2007
9,946
655
58
Fairborn, Ohio
Joe
Same here...Thought I was losing my mind, checked and it was still set at off. Same thing with my email check. I have it set for manual, but it still checks all the time...not just yahoo's push, but my RR accts too.
Jun 27, 2007
198
Whell depending on the brightness you like, Auto-Brightness can either drain your battery or save it. If you have your brightness set relatively low many people seem to get better battery life with it turned off, as reported in the Battery Usage thread.
BIGTIMEBALLER504
Jul 9, 2007
122
i have my brightness half way with auto on so shud i turn it off? or leave it
