Another iPhone 5 hint, or just me?
DaleRobertk
Sep 11, 2012
Yeah it appears as though the new iPhone screen will be taller in height. I am most concerned with how this might effect the aspect ratio. Does anyone have similar concerns?
Leo
Nov 9, 2008
901
137
43
31
Calgary, AB
I'm pretty sure old apps that define a size will be letterboxed such as games, otherwise as long as they use the Apple GUI already, it should fit the new screen size automatically. The same applied to a lot of apps that had no need to update for the retina display a couple years ago.
DaleRobertk
Sep 11, 2012
I hope that is the case. If it is true than my apps should be just fine. I have my fingers crossed!
