Another iTunes Problem
Ldc4S
Aug 7, 2007
73
Dallas, Tx
I'm on a PC, everytime I exit out of iTunes after I'm through with it, it stays in the task manager. The program itself exits out but it stays hidden in task manager. So I have to actually go to task manager and press End Process for it to completely exit out. Anybody else have this problem? This is a new computer by the way.
josephsv
Sep 27, 2007
same issue man, don´t now why, but its sucks :(
neosir10
Jan 21, 2008
Hellooooo
Hi there,
About your iTunes problem. There could be a possiblity that you have not actually closed it yet. Sometimes you can click on the close button but the iTunes would simply minimise to the bottom right where the time is. If you could check there and if you see it you could right click and tell it to close. Im not sure where the option to take that thing off is but it should be somewhere in preferences. Hope I helped:)
Take Care
