Answering the Phone
Sep 16, 2008
Not so much a problem as a curious question. When people ring me sometimes i have two buttons appear on screen one saying answer the other saying reject. At other times though I just have a button whgich says slide to answer. There seems to be no pattern to this and just seems completely random.
Does anyone know why this is, and also when it gives the slide to answer option how do I reject a call?
aq.timmy
Aug 3, 2008
23
Grand Rapids, MI
It's not random. You get the slider when your phone is locked, and you get the two buttons when you're actively using the phone (when it's not locked).
To reject a call when your phone is locked, just press the sleep/wake key and it will send it directly to your voicemail.
kevroc
Jul 16, 2008
43
I think pressing the sleep/wake key once silences the call and pressing it twice sends it directly to voicemail.
Smokey
Sep 17, 2008
93
either way if you silence it you don't hear it, then it'll eventually go to voicemail anyway.
