Any advantage to 6.0.2 over 6.0.1?
NHL Fever
Mar 15, 2010
80
I'm not sure if I should upgrade or not. Sounds like the only improvement is a bug fix for a possible wifi issue. I've never had any wifi issues. I'm also reading that it may worsen battery life.
Sounds like it doesn't matter either way wrt jailbreak, it would likely work for both when released.
So should I upgrade?
Also just to clarify - upgrading now would go to 6.0.2 not 6.1 right? 6.1 is not out yet right?
Don't bother with 6.0.2. It's nothing more than a WiFi bug fix and the official release of 6.1 is right around the corner. The final 6.1 beta came out yesterday. It can be activated without a developer registration code and it has no release-type lockdown keys. So this version is basically a GM (Gold Master) and releasable as a public 6.1.
liberated
Jul 19, 2007
3,238
484
No advantage (wifi ...yes right!) if anything disadvantage as some users report poor battery life after update. Wait for 6.1.
Sent using iCafe app
NHL Fever
Mar 15, 2010
80
Ok thanks for the advice. I'm working on the assumption that if the iOS6 JB gets released, it would be after 6.1 and thereforee good for 6.1? On the off chance that it would not, I will probably hang onto 6.0.1 until the JB is released.
The jailbreak will be for 6.1.
