Any advice on freezing while booting issue?
NHL Fever
Mar 15, 2010
80
Did the 6.1 JB. So far most everything is fine. However, if I shut down my iPhone5 the standard way then boot up, it freezes at the Apple logo. If I then do home+power shutdown then boot up, it boots normally.
Any thoughts?
MoneyMaker79
Dec 15, 2008
5,386
340
30
Pensacola, FL
Any thoughts?
Do you have any addons that may have caused this? I know I tried the Siri addons, and when I would attempt to use them with Siri, I would then reboot and it would hang at the Apple logo.
ironlungakc
Aug 26, 2007
94
Ok so Im stuck on the Apple logo right now...how to I unfreeze it? HELP
MoneyMaker79
Dec 15, 2008
5,386
340
30
Pensacola, FL
To unfreeze it, hold down both the power button and the home button until the Apple logo goes away, then it will reboot. This is a "hard reboot." Then what you should do is look through your Cydia apps and make sure none of them are the culprit to causing the freezing on start up.
