iPhone XS Any advise on iPhone battery like always being low?
catti
May 20, 2019
Even though I have brought a new battery and changed settings etc??
Someone please can you help me...
barbdVegeen
Jun 10, 2019
If you are having issues with your phone even after putting in a new battery, that means you got trolled. doesn't work even with the new battery and adjusted settings? I would recommend on getting a new phone. that might be your only salvation considering the fact your new battery isn't doing what its supposed to do.
Kevin Barnes
Jul 23, 2019
19
The battery is draining fast due to many reasons. First, you have to disable all the background apps. Then clear all the junk files and cache on phone memory. Then check the battery status again and manage the apps that you are using. customized devices have draining much power than the regular one. So resetting all the settings into normal would be good. but after all this kind of activities you still suffering the same problem the new battery you have bought not be a quiet genuine one. Replace it with a genuine one is the best solution.
