Any iPhone 3G(S) cases that fit in the dock and have a grip to them?
sofakng
Dec 4, 2008
While I'm trying to figure out if my InvisibleShield is OK or not I thought I'd ask another question...
Do any iPhone 3G(S) cases fit in the dock without having to remove a part of the case (Incase Slider) or flip a part of the case (Contour Flick)?
I'd also like the case to have a bit of a grip to it and not attract a lot of lint.
Basically I'm looking for something to act like the InvisibleShield (for the back of the phone) but in a case format. :)
Kuntry
Mar 26, 2009
318
Las Vegas
I just ordered this one but I haven't received it yet:
http://www.switcheasy.com/products/Rebel/Rebel.php?color=devil#
Comes with a dock adapter (you shouldn't have to remove the case), 2 screen protectors, dock connector plug, micro towel, and a video stand to prop it up. I got the red/black setup but you can mix and match whatever you want. The material is not silicone, its a soft polymer so it wont be as flimsy as silicone but its still not like a hard plastic case (incase slider) then the acrylic piece holds it snug and adds protection.
dano31415
Jul 30, 2009
docking station that fits while cased
You have several options for docking stations that are made to fit your phone with the case left on.
Seidio Innodock
or
made2dock
http://made2dock.myshopify.com
I think Griffin makes one too.
