Any tweak to remove dock background
rugved1118
Sep 27, 2013
637
Hello,
I am using Harbour and would like to remove the background of the dock. Please check out the screenshot. Can anyone please suggest any tweak for this ?
28,365
5,506
You only want Hide Dock Background toggled on. Toggle Hide Dock off. Do a hard reset after you toggle Hide Dock off. If it still doesn't disable it after that, make sure Settings > General > Accessibility > Increase contrast > Reduce transparency is not enabled.
rugved1118
Sep 27, 2013
637
Do you Hard Reset by pressing both power and Home button at a time ?
I have checked, Settings > General > Accessibility > Increase contrast > Reduce transparency is not Enabled.
rugved1118
Sep 27, 2013
637
I did a hard reset by pressing both buttons at a time, but the background dock remain unchanged.
Could you please assist me ?
rugved1118
Sep 27, 2013
637
As always, you are simply Awesome.
After Disable on springboard is toggled on in the Eclipse 2 settings, followed by a reboot, worked fine.
Many thanks Europa !!
I humbly request you to please assist me resolve my issue in this forum too.
