any way to get to apn settings on beta 3
icecreamman2
Jul 23, 2008
207
san francisco/vancouver
so long story short i had MMS working on beta 2 but when i went to 3 it changed my apn settings back to default, but on the third beta if you try to click " cellular data network" in settings it crashes.... any other way to change my apn settings to get MMS?
iNinja
Aug 8, 2008
3,984
20
UK
You need to shift update the IPCC file. Search google.
iphonewarrior
13,847
701
I'm still waiting on my 3.0 beta... I'm dying to get on the list! Croucher you'll have to show me the way!
iNinja
Aug 8, 2008
3,984
20
UK
its easy IPW... all it takes is a donation and you can get it up and running in a day (the longest part is waiting on the dev to add you). If you like, i can get you added, but you will have to send me your phone's ID and the guy $5 via paypal
iphonewarrior
13,847
701
I've payed taewing 10$ by accident instead of 5$ I'm a bit annoyed. The thing is I haven't heard anything back yet, slightly concerned!
iNinja
Aug 8, 2008
3,984
20
UK
really? He is normally pretty good with emails etc, im sure there must be an explaination!
iphonewarrior
13,847
701
Still waiting back right now, i'm sure he's busy or something, at least i've done my bit anyway.
can i just ask, obviously there's new updates coming out for 3.0 beta all the time, how do you get these? does taewing contact you to let you know where to download the FW from?
Also- by iPhone ID do you mean IMEI or serial?
iNinja
Aug 8, 2008
3,984
20
UK
Taewing emails you with a link to download the updated firmware. Then you just shift update in iTunes.
Its called a UDID and to get it, plug your phone into iTunes and click on serial number - it should change and show your UDID.
iphonewarrior
13,847
701
I've just made myself look stupid when i knew exactly what to do!
Never mind...
Just had an email off 'Trev the Dev' he's out and about at the minute so he'll sort me out later on.
Crouch is there any chance i can rack your brains once i'm up and running via email etc... ?
chavezr6
Sep 9, 2007
I've tried this several times and i've had the carrier update to "5" and to "5.0" neither one allows me see anything. Just a blank page. The "5" would crash back to homepage.
the_monitor
Sep 30, 2008
101
MA
Bump for having the same problem. I am using ATT 5.0
iNinja
Aug 8, 2008
3,984
20
UK
Of course you can, im available by email any time of the day, check you PM ive sent you my addy!
