Anyone else's mini take hours + to charge?
Torinate
Sep 19, 2009
325
Just got a mini for the kids to play on.
I charged it initially and only once since then.
This time, I kept track a little more. It took 6 hours to go from 29% to full charge. No apps running. It was not being used while charging.
Is this normal for this model? I'm used to my phone that charge lickety split.
Thanks!
Torinate
Docd
Oct 16, 2011
651
62
Mini has a lot bigger battery so will take longer to reach a full charge as compared to an iPhone.
Torinate
Sep 19, 2009
325
Mini has a bigger battery? How much bigger? Just seems really really long to charge. But, if this is what others see as well, that's fine too. Just wondering if I've got a problem...
Thanks!
Docd
Oct 16, 2011
651
62
My daughter has a mini but never timed how long it to charge. I have a iPad 3 and it can take 8-10 hours to charge. The battery is I'm guessing more than twice the size. Figure that most all the internal components are about the size as the phone except the battery and the display. They would fill as much space as possible with the battery to power the display and give the iPad as much user time they can.
glsda
Oct 17, 2007
1,440
50
California
When I charge my iPads, to include my Mini it appears that they charger faster when using the converter on the bottom. I have never really paid that much attention but I am sure someone in the forum will provide the answer.
Jerry
Ohmster
Jan 26, 2008
533
21
SoCal
Jerry
I believe the top one is 1A while the bottom one is 2A. Check the small print on each.
Sent using iCafe on iMini
Docd
Oct 16, 2011
651
62
The top one is a 2.5 watt and is made for iPhone and iPods the bottom is a 10 watt and is for iPad and MacBooks. You can use the bottom on the iPhones and iPods but if you use the top one one the iPad it will charge but it will be very slow and if your using it at the time it's almost a wash.
Torinate
Sep 19, 2009
325
Hmm. It came with the top one.
It appears to have the same charger as the ones that came with my phones. Guess ill look at the fine print. I always thought they were the same.
Ohmster
Jan 26, 2008
533
21
SoCal
From what I recall, the top one comes with iPhones and the Mini. The larger one for iPads (at least through iPad2).
The MacBooks (the Air for one) come with something similar but no USB output.
glsda
Oct 17, 2007
1,440
50
California
There's that magic Napoleon was talking about.
radtechy
Jul 20, 2011
505
41
I use an Apple 12W power adapter with my iPad mini and can go from zero to fully charged in just under 3 hours. That seems pretty damn quick to me.
That's the adapter that comes with the big iPad? My mini came with the same exact charger as the iPhone gets and has the same electrical specs
Sent using iCafe app on my iPad Mini 32 GB
Kobel1up
Mar 14, 2012
160
Eastern Ohio
I just got my mini so I don't know how long it will take to charge. I know my ipad 2 takes about 5 or 6 hours, which is fine because I get 10 or more hours us and 11 days stand by.
