Anyone have Trouble installing levelpacks to IPhysics on broken 1.1.3?
Rockky
Aug 8, 2007
333
looks like they went ok but don't show up when I click the game.
I saw some kind of iphysics fix install...thats probably the solution but I get the script error when trying to install...dang, Iphysics was a key reason I broke the firmware!
mflantin
Nov 29, 2007
100
I installed something called "iPhysics All Levels" through isntaller, it installed a bunch of levels on my iPhysics and so far looks like most of them work. It's from the iSpazio Source.
bean22
Dec 13, 2007
65
Where can I find the iPhysics fix? Is it in installer, and if so which source do I need to add?
Jhors2
Nov 11, 2007
239
If that doesn't work SSH the phone and go to /private/var/root/Media/iPhysics/Games/Crayon_physics and basically change the permissions of everything in there to 0777, it worked for me
Panth
Jan 30, 2008
no offense but I hate ssh its useless. You can use a simple drag and drop program called iPhonebrowser to add Roms and things and you can change permissions with squid from the installer app. So just use squid to change the permissions on it if the other way doesn't work.
Rockky
Aug 8, 2007
333
If I could please ask, what and how do you 'SSH' your device?!
I DO have SSH, and Mobile Finder downloaded, btw.
Thank you.
