anyone miss 2 space keys = a period?
sbpwjm
Jul 25, 2007
41
i find myself hitting the space key twice expecting a period ala BB...
any shortcuts like this for the iPhone popping up?
thanks!
sbp
stevetim
Jul 20, 2007
606
Someone helped me out a great deal with how to type 'period' and not actually have to tap,type,tap to get it. Just hold down '.?123' when typing texts, slide your finger up to the '.', then let go. It inserts a '.', then reverts right back to the letters screen. About the most useful tip for iPhone yet!
AngelJO008
Jun 20, 2007
140
thanks!
sbp
I keep doing the same thing myself coming from a BB8800. I was hoping this was also the case for the iPhone, but someone in another thread stated that if you hold the 123 (alt) key while sliding your thumb to the period button not only types the (.) but also then goes right back to the (abc) version of the keyboard. I have found with time it's almost as second nature as hitting the space key twice for the (.)
wildonrio
Jul 4, 2007
2,002
Provo, UT
GREAT TIP THANKS! This also works just as well with commas, exclamation points, and question marks I just noticed (or any punctuation for that matter)! :cool:
Velodog2
Jul 19, 2007
562
Of course if you insert a space character between sentences (and I see that you do...) then hitting the space key in the .?123 screen sends it back to ABC screen also. Apple has your back...
Dawgfan
Jul 27, 2007
347
Atlanta, GA
To answer the original question.. .YEEEESSSS!
Until Stevetim solved it.
Best tip I have found yet stevetim. This may actually be easier than the BB double tap and I LOVED my 8800.
Now if someone can tell me how to get Yahoo Mail to receive messages (it can send them sometimes) I will be stoked.
'preshate the tip!
sbpwjm
Jul 25, 2007
41
"the slide" is great... can be used for anything as long as you slide and don't lift your finger you can get to any character you want... 9, @,... whatever..
