Anyway to make this work?
socalkevin21
Jul 8, 2007
114
I have a Sidekick 3 and all my numbers are backed up to the T-Mobile Server, is there anyway to transfer all 700 numbers to the iPhone once I switch the the 19.99 or 5.99 tzones? Any help would be appreciated... Thanks
Dragoro
Sep 9, 2007
140
People at modmyiPhone might be able to help better with that, or in the mod section here.
skiz420
Jul 28, 2007
371
Boston
there has gotta be a way to export the contacts from the server to outlook or yahoo contacts... you can login and see all of your contacts right? (like paris hilton) then you should be able to export them somehow to outlook
skiz420
Jul 28, 2007
371
Boston
k i just logged into my dads account on t-mobile... if you go into the desktop on there acn check your address book you can see them all and they have a sync option... thats the good part... bad part of is they use a propritary software for the sync called intellisync or some thing like that... and its 10$... so i think that word work if you wanna shell out 10$ to tmobile for a simple sync software or just retype the 700 contacts in your phone... or you could get something like this...
http://www.pacificgeek.com/product.asp?c=286&s=1293&ID=36019&P=F
