Anyway to put music/movies on when not on main computer?
detz
Jun 28, 2007
31
So iTunes is setup at home for my iPhone but sometimes at work I download something I want to watch/listen too. Is there a way I can put this on my phone without removing all the stuff from the iPhone when syncing iTunes?
Aug 27, 2007
Bumping this thread because I have the same issue too. Is there a way to map a drive to the iPhone like every other mp3 player does?
geordisjd
2,442
iTunes on the 2nd computer will erase the previous files (from the first one) when you sync, unless you have the exact same files on both, in which case you can add some other video files. You can also use iPhoneDrive to transport your video file on iPhone as a hard disk, put it on computer #1 and import in that first iTunes, than sync. Good luck!
