Anyway to set permissions without using WinSCP?
wildonrio
Jul 4, 2007
2,002
Provo, UT
WinSCP just gives me connection timed out every time I do it so I need an alternative. I've tried using Manzana but I can't set the permissions with it. Is there another program I can use, possibly one with a direct USB connection like Manzana but with the ability to set permissions?
Without setting those permissions, all of my new applications just open, hang, and then close.
Conan
Jul 19, 2007
374
As far as I know, WinSCP is the only way to change permissons on the iPhone so far, haven't really seen other ways..If I do I will post.
SiLeNtKiLLa
Jul 4, 2007
134
Atlanta
Its possible, but you have to have the Terminal.app installed and already ssh'ed with permisions. You can also download putty and use that instead of WinSCP, only thing is putty is not as user friendly as WinSCP but more like Terminal or Command on windows.
After getting Terminal up and running on iPhone, you can set permissions using that, just browse to designated app folder, and do what ever it is you need to do.
wildonrio
Jul 4, 2007
2,002
Provo, UT
Well now I'm in a paradox because I can't set the permissions in Terminal without using Terminal! Haha
Rayne
Aug 21, 2007
Have you tried Putty? When I was modding on a Windows machine there were a few instances where I couldn't connect using WinSCP but could using Putty.
In fact, a couple times, after I could connect using Putty, I could just exit and go back and connect using WinSCP - dunno why.
Tinman
4,334
183
Aridzona
Mobile Squid, available through iBrickr and Installer, will let you set permissions.
Mike
