AOL After 2.2 won't allow me to delete
jlawlor
Jun 21, 2007
9
I update to 2.2 and for some reason - I cannot delete mail - either one at a time or in bulk - I get a message "Unableto Move Message" The message could not be moved to the mailbox Trash. I deleted the e-mail account and reset it up but it didn't fix the problem. Anyone have a fix for this? Thanks
Panache010
Aug 19, 2007
565
77833
Me too. I can only delete them from my pc but not from my phone.
Tug
Aug 4, 2008
528
Count me in, I cant delete my email while using AOL on my iPhone either. The few pictures I downloaded from my email are blurry as well. I'm going to go to Verizon and check out the Blackberry Storm tomorrow, this is getting ridiculous.
Thank you Apple
Tug
Aug 4, 2008
528
I deleted my AOL account and put it back in. Now everything works fine.
I deleted my AOL account and reinstalled it, didn't work :(
showguy
Dec 2, 2007
769
Long Island, NY
Go to your AOL account// advanced. Look for the "deleted mailbox" option. Make sure it is pointed towards 'on my iPhone// trash.
Tug
Aug 4, 2008
528
It's checked off but thanks for the suggestion. I'll give Apple a call a little later.
Tug
22
I tried the email reset and network reset with no luck. These updates are pointless. I want my 2.1 back. Any other suggestions?
Dukeboy0169
Jan 10, 2008
Anyone find a solution yet? This is REALLY annoying.
Tug
Aug 4, 2008
528
To me it's not so much that it's annoying it's just that the phone isn't doing what it's meant to do all because of a software upgrade. Than when you consider how much it cost me to get out of my Verizon contract and buy an iPhone it only exasperates the problem.
Tug
Aug 4, 2008
528
For whatever reasons I can now delete my AOL email on my iPhone.
Tug
22
I have my aol and yahoo email accounts on my phone. If you go under mail settings, then click the account, then advanced, I noticed under yahoo it says on the iPhone and on the server. Under my yahoo account, both server and iPhone settings are set to trash. But aol I can only set the iPhone option to trash and there is no trash option under server.
Did Apple delete it?
Dukeboy0169
Jan 10, 2008
I tried altering all the settings, deleted the account and reinstalled. I don't think the user can resolve this issue. I just hope we don't have to wait until the next update.
22
Thanks for the info, if Apple continues down this track, I'm going for the storm. This is ridiculous. My "on the server" options are:
Inbox
Drafts
Sent Items
Saved
SavedIMs
Spam
VOICEMAIL
No trash...How odd.
Edit: 10 Minutes Later.....I can delete messages. HA
danni71083
Dec 1, 2008
Tug
This was happening to me also. Mine was checked but I clicked it again just to be sure and even though it appeared to do nothing, it worked. Now my messages are going to the trash.
TSheridan330
Dec 16, 2007
56
Danni'e solution worked for me. It was checked and I presses it anyway. Mail working. Try it. This is under advanced, deleted mailbox.
24trepid
Jan 13, 2008
502
Checking trash, even though it was already checked, fixed mine.
I can delete mail again ....... woohoo .......... :cool:
eric100
May 28, 2008
my answer
Had the same problem. Did everything as above. Nothing.
Then I went to settings,mail,went to my acct., advanced, and just reset all of the options. More or less turn them off and then turned them back on. Bingo.
