AOL mail - How do you check it?
greeky83
Jun 27, 2007
14
How do you set up the mail ? Im so confused on how that works. Do you set it up with the mail thing on on the phone or do you just check it through the browser?
kycophpd
Set it up through the phone then it can check automatically at different intervals. It works great!
Set it up under the mail setting under add email, then choose AOL and follow the prompts. Just keep in mind that if you read a message, it also shows read when you check from a computer later. Anything with attachments or something important in the text, i save to the saved mail folder while i have the message open, then i can find it easier on my computer later and can download and print.
Also works the same way if you delete from your iPhone - your message will be deleted for good. My blackjack only deleted it from my phone and i could still find it as new on aol on a computer. It took deleting two important messages to find this out!
Sent from my iPhone
greeky83
Jun 27, 2007
14
Im not sure how to fill out the thing. Im kinda slow in this section lol. How do you set it up. Like what did you type in
kycophpd
Home screen - click settings - click mail - on top of mail settings screen is add account,click that. After that, click the AOL icon and you can't mess it up, it walks you through it. This is assuming you already have an AOL account.
Sent from my iPhone
