App Icon/Images
veks808
Apr 12, 2008
17
I was wondering if someone could guide me step by step on hOw to create springboard icons/app images with my own pictures? Thanks in advance>
15,385
1,089
there are five main steps involved in this:
1) resize the image to 60x60
2) save it as a app.png, where "app" is replaced by the application's name
3) create a "theme" folder (it can be called whatever you like) that contains these items (use the exact spellings):
-Icons (a folder with your custom icons in it)
4) Use SSH to put the entire theme folder into this directory on your iPhone: /private/var/mobile/Library/SummerBoard/Themes.
5) Go to summerboard, and load your new theme just like any other you'd get from installer.
It also makes the icon look better if you place a semi-transparent semicircle gradient over the top half of it. All of Apple's icons have this.
- John
veks808
Apr 12, 2008
17
Hey that was easier than I had thought. Worked perfectly. Thanks a bunch!
