App store problem!
butur
Mar 10, 2009
I went on app store on my iPhone and there were some updates so i updated but it shows on the app loading and then gets stuck on install. What to do what do do?
iphonewarrior
13,847
702
Is it simply not installing onto your iPhone?
MrEous
Dec 11, 2008
649
Dallas, TX
Try updating from the App Store icon on your springboard yet?
butur
Mar 10, 2009
from my springboard? as in from the phone it self? (new iPhone user:)) if you mean that then yes, i went on app store in my phone not iTunes and selected update. then it says just loading... and there does nothing happen it's stuck on it?
also if i install from app store on my iPhone does it come on iTunes?
iNinja
Aug 8, 2008
3,984
20
UK
You have to use iTunes to install them if they have frozen. Open your iTunes and check for downloads, they should be there. Sync then your good to go
